wheel axle nut
Old Oct 20, 2010 | 12:22 PM
vt cat atc newbie's Avatar
Default wheel axle nut
I'm having a hard time getting a lug nut off the left rear wheel.
I noticed the wheel was a little loose when I replaced the disk brake pads and cannot get the nut to budge. I've removed the cotter pin, and have tried a braker bar with a socket. Haven't gone so far as to try an impact wrench with a socket yet.
Any suggestions?
Old Oct 20, 2010 | 04:18 PM
mudslinginfool's Avatar
Does it in the Mud!
Id just try the impact.
Old Oct 20, 2010 | 06:14 PM
TLC's Avatar
TLC
YouTube - Changing ATV CV boot on 2003 Arctic Cat 400 Automatic just like this guy had to.
Old Oct 22, 2010 | 09:47 AM
swampyjunior's Avatar
Soak it with WD40 or penetrating oil and let it sit over night. Then use an impact wrench it should get it. Once you get it loose and before you re-assemble it put some anti-seize on the threads to help in the future.
I think the castle nut is 28mm or 30mm.
Swampy
Old Oct 22, 2010 | 12:42 PM
09 popo HO's Avatar
Breaker bar with a 4 foot pipe on the end. That is what I did last night.
Old Oct 22, 2010 | 02:30 PM
Mehoe's Avatar
Wd-40 ftw
1000gade
Sep 9, 2015 04:41 PM
meddy0388
Sep 9, 2015 06:41 AM
bmark0610
Sep 7, 2015 09:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
