2006 Arcti Cat 500 4x4 Part Identification
Greetings.
I am trying to find out what this part is called or does.?
One of the wires is smoking when we try to start it.
Repaired and replaced the wires, but they still smoke
It is a 2006 Arctic Cat 500 4x4 with manual shift 5 speed.
Any help would be appreciated..
Part Installed close up
Part Installed
Part Installed
Part removed, what is under the part
Where the part goes
Part Removed
Part Installed
Part Installed
Where the part goes
Part Removed
Welcome to the forum!
I went to COUNTRYCAT.NET and pulled up a parts schematic of your machine.
The part your wondering about is the GEAR SHIFT POSITION SWITCH #SKU: 3402-816
I'm assuming there's a indicator on your gauge pod that shows you what gear your in.
Hope this helps
Hope this helps
Thank You
This least expensive I can find this part online is $80. The same part on the same year Suzuki Vinson is $50. Do you know if Suzuki and Arctic Cat Engine parts are interchangable?
Why are the Arctic Cat Parts so much more expensive?
cody500ho
14
Aug 14, 2015 05:03 PM
Jul 22, 2015 05:00 AM
