Electrical problem
Old Mar 8, 2011 | 12:12 AM
rappy01's Avatar
Default Electrical problem
Hey everyone, i have a 06 arctic cat dvx 250. Recently the headlight and brake light both went out. Both bulbs are good. I checked the fuses and it was good and i even replaced it and still no lights. I replaced the voltage regulater and still no lights. All wires are connected at the socket too. Anyone have any ideas of what else to check. I thought maybe the key switch for the lights or the light switch. But it still doesnt explain why i dont have a brake light. Thanks
Old Mar 8, 2011 | 07:35 PM
07 400's Avatar
Check with a volt meter to see if you are getting any ac voltage going to the light.also check the stator to make sure you are getting voltage out of the lighting coil.
Old Mar 9, 2011 | 11:50 AM
rappy01's Avatar
where is the lighting coil located at?
Old Mar 10, 2011 | 08:04 PM
07 400's Avatar
In the stator under flywheel in the motor.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
