700 efi does only 50 mph
Airdamm does good work. (800-1000 miles on mine)
The cat and the king use the same motor with a dry clutch.
I did 1+2 on mine with lighter rollers and it made a world of difference.
I also twisted my main spring (didn't replace it at the time there was none avail an Adam (airdamm owner)told me to do it)
The low is great and 2 hi is much better for clearing logs and such.
A buddy of mine with a grizz still had the delay from 0-10-12 with his after doing a mad mike kit but he has the wet clutch. There is a ton of info on the wet clutch delete on Grizzly Central.
For all you grizz folks he overcame the wet clutch with a bolt on power tip. everything I read about them was crap but for him with the mad mike work it overcame his wet clutch. Also he didnt have to change his fuel air mix. (no chip)
