2007 arctic cat efi,
Old Feb 9, 2013 | 10:46 AM
papathud's Avatar
Default 2007 arctic cat efi,
just rescued a 2007 efi.new to arctic cat here.front wheel drive not engaging and battery dosent appear to charge "which wont be hard to indentify im sure,but just wanting to test the water as to anyone know any obvious quirks or problems, seems like a good wheeler or can be,and looking forward to putting it back in shape. thanx!!!
Old Feb 9, 2013 | 11:06 AM
mudslinginfool's Avatar
Does it in the Mud!
I have to ask to be sure, are you hitting the 4wd button or flipping the diff lock lever. There has been a few issues ive seen with the actuator stripping out which will not engage the 4wd but you may be able to hear it. If you listen you might be able to. If the diff lock is not engaging,then i dont know, cable broke maybe? The battery may not charge because it may be shot. If its a stock battery and has been sitting for a while it probably wont work. they dont last too long. Alot of the guys on here switch to an upgraded battery that lasts alot longer and easier starts in the cold. I cant remember the name but it has "680" in it i think. someone will help soon with that im sure.
Lets see some pictures of this "stray cat" you rescued!!
Old Feb 10, 2013 | 06:08 PM
Kerbbirds's Avatar
Need a good battery for everything to work right.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
