2000 arcticcat 500
Old Feb 19, 2013 | 11:55 AM
Michael Schwab's Avatar
Default 2000 arcticcat 500
im having truble geting my quad going it needed a new starter relay so i put on new one tryied to start it but all itdoes is click can someone help
Old Feb 19, 2013 | 04:21 PM
Cummins Driver's Avatar
The starter itself may be bad... Run a jumper cable from the positive lead on your battery directly to the terminal where the wire connects to the starter. If it cranks then you know you still have a bad connection between the battery and starter. If it doesent crank then you know either the starter is bad, the battery is weak/bad, or the engine is locked up.
Old Feb 19, 2013 | 08:32 PM
it turns over when upull start it but il jump starter to see it its dead
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
