I kind of feel like an idiot
Old Sep 29, 2013 | 11:41 AM
redsoxfan's Avatar
Default I kind of feel like an idiot
I am finally caving in and setting aside my ego. Although I never claimed to a master mechanic, I usually am someone above completely helpless when it comes to general ATV or car maintenance and simple repairs.
I bought a used 2008 Artic Cat ATV that was running pretty well until recently when after about 3 or 4 minutes the ATV ceases to move fw or backwards. I replaced the oil, added axle lubricant, etc. I am trying to find where to add antifreeze, but have completely failed. The manual tells me about a radiator access panel on the front hood of the ATV, but there is no radiator access panel on the hood of my ATV. Its a solid body with no panel. I don't want to completely take apart this ATV to put antifreeze in.
Does anyone have any suggestions? Anyone encounter this before?
Thanks- complete newbie
Old Sep 29, 2013 | 04:50 PM
redsoxfan's Avatar
Also, it's an Arctic Cat 400, 2008 model. It seemed to overheat, and other than an oil change, I figured coolant was the next thing to change. Any suggestions?
Old Sep 30, 2013 | 10:11 AM
TLC's Avatar
TLC
There is two Arctic Cat 400s. I take it that yours is the sporty DVX?
2008 Arctic Cat 400 DVX ATVs
Old Sep 30, 2013 | 12:55 PM
sr.ruedas's Avatar
If you have the DVX400 and not the utility 400 4x4, then you DO need
to remove the front fender plastics to get at the radiator cap. However,
the overflow cap it accessible on the left side without removing anything.
I just drained/replaced coolant in a 04 DVX400.
Sounds like your manual is for a 4x4.
Old Oct 2, 2013 | 07:40 AM
redsoxfan's Avatar
Thanks for the replies. Actually, I have the utility 4x4.
Old Oct 2, 2013 | 08:08 AM
TLC's Avatar
TLC
In that case its not a liquid cooled motor. Its a Air/oil cooled 376cc motor made by Suzuki.
The radator looking thing is a oil cooler.2008 Arctic Cat 400 4x4 Automatic Reviews, Prices, and Specs
Its pretty well impossible to over heat that motor , even if the oil cooler fan did not work the oil cooler still does its oil de tour job, the fan is just a assist device.
What makes you think its over heating? Is the oil temp light coming on?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
