New to me 1998 300 4x4
Old May 14, 2014 | 05:23 PM
5point9's Avatar
Default New to me 1998 300 4x4
Well I am new to Artic Cat. I just came across a 1998 300 4x4 that is in good/average condition. The owner said it wasn't running right probably needs carb work.
It fired up but started pouring tons of gas out of the breathers. Long story short, I drained 2.5 gallons of gas/oil out of the crankcase. Good thing we didn't run in long.
So I assume the float is stuck. I will work on that.
I will start having questions and here are my first two please.
1. Under the air filter housing is a 6-pin connector that appears to go to the gearbox. I believe this is because it was optional to have a speedo with shift lights? Perhaps that it what this is for? Needless to say I don't have that option. The connector is not connected to anything.
2. The carb only seem to have one vent line, and it simply loops from the top right to the top left of the carb. No other drain lines, overflow lines, etc.. does this sound right?
Thanks guys!
Old May 14, 2014 | 06:11 PM
5point9's Avatar
On another note, he said that when it warmed up it would run rough and die. What would cause that? Besides cleaning the carb, adjusting the valves, new plug, fresh fuel what else should I look for?
Old May 15, 2014 | 09:02 AM
Zrock's Avatar
Super Quad Patrol
Sounds like its all coming down to just a carb rebuild.. Just make sure you get everything good and clean and that all the little holes in the jets are clean and you should be good
Old May 15, 2014 | 10:31 PM
5point9's Avatar
Some more help. On my carb there are two nipples at the top of the carb, about 2 o'clock and 10 o'clock. Currently they are tied together. What are these two lines? Vent lines? Should they be tied together or routed somewhere else to atmosphere? Seems odd that they are tied together.
Please advise. Thanks!
Slagpolaris
Sep 5, 2015 09:41 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
