2006 Arctic Cat 450 4 wheeler belt and clutch questions
I have a 2006 AC 400 that needs a new belt and possibly a new clutch.
Im new to working on 4 wheelers but very mechanically inclined with cars/trucks etc.
Do i need to purchase all new clutch parts or is there a "clutch rebuild kit"?
Any tips/advice?
The belt is obliterated so def needs a new one.
Where can i find parts for this 4 wheeler?
Thanks
Any tips/advice?
Thanks
Here's a little info on a 400....may only need a belt....and there are less expensive sourses like maybe ebay.
DIRT CHEAP ATV PARTS' 2006 Arctic Cat 400 FIS AUTO (RED) [A2006ICH4BUSR] | TRANSMISSION ASSEMBLY Parts List[A2006ICH4BUSR]%20TRANSMISSION%20ASSEMBLY
How can i tell what model ATv that i have?
Its red and black 4X4 (automatic i think? it has the lever on the left side with low, high, neutral and reverse).
TRV?
FIS LE?
FIS AUTO?
Or will any of the 400 belts fit?
TRV?
FIS LE?
FIS AUTO?
According to some on an Arctic Cat forum the 17 digit vin number is located on the frame just above the rear tire. 10th digit is the year model.ATV Vin Number : Check and Decode Your VIN
I believe the FIS has something to do with the suspension, tho I'm not 100 % sure. The TRV is a 2 passenger, LE just stands for Limited Edition ( wheels, colors, graphics ), Auto means no gears to shift ( has hand shifter, high, low, reverse..etc )...belt drive. Any of the 400 CC class belts will work....
Nathan007
Feb 15, 2016 11:54 AM
