2015 Arctic Cat XR 550 XT or 2016 Polaris Sportsman 570
#41
GC
#42
Put it in high gear and see how it feels launching from a complete stop. If you're going to go up a couple tire sizes you might want to see what your clutching options are. Oversized tires will put a lot of stress on the transmission, especially getting going.
#43
Well, I went out yesterday to get a new set of tires. Saw Wild Thangs on sale and liked the look of the tread pattern, so I bought a set. I wanted to step down a size from the 27 inch Mud Lite XTR's, so I bought 26x9x12 fronts and 26x11x12 rears. The tread is a more aggressive tread so I'm not sure that stepping down in size will make any difference in abiltity to spin the tires!! Total weight of the 4 tires is 96 pounds. Hopefully this will work out ok!! Any of you know anyone running these tires?
#44
Arctic Cats are geared for work. Absolute top speed is not their forte. I had mine on a Mustang Dyno, rwhp was not impressive, but torque was . I've only been stuck once with these 30" Mudzillas (fell thru ice into 18" of water, had to winch out) I think you should have gotten bigger! I'll probably put 27's on my AC 400 when the 25's wear out. Mine is a 2001, front end is different. Mudzillas weigh 42 lbs each!
#45
So it sounds like you believe my 500 stock will have no issues with these 26 inch Wild Thangs. Correct?
GC
#46
I meant you have the "Pretty Jeep" front end like my 2002 AC 400 has, haha. I think we have the same gear ratios, though mine has a straight rear axle. That Suzuki 500 has gobs of torque, though. I have done a few mods to the motor, Web Racing cam and a 5 degree timing advance key. Mine is manual shift, so I have essentially 10 speeds fwd and 2 in reverse. Having not driven the CVT model, I'll still bet you'll be surprised when you dog her down. I've been plowing snow with a 72' plow, thing really has grunt. I predict that you will be like your friend and drive around the mud, she's just too darned pretty!
#47
Lol. I guess I will have to agree with you on most points. However not the driving around the mud. I have friends that won't go with me because they know that my motto is if yer not stuck yer not having fun!! I see it I gotta try it!!
Hope you're right about the torque!!
GC
GC
#48
I'm running 27" tires on my 500 with stock gearing and clutch. I have no issues barley noticed the difference between our 2 500's the other had stock tires. I've even been known to pull the front end up and wheelie it down the road
#49
Once you get used to oversize tires , just for a laugh, put the 25's back on if you kept them on the old rims. I was bored one day, saw the old 25" er's (Carlisle 489) sitting in the weeds, and for a laugh put em on. HAHA, traction was useless. Way faster with the 30's! GPS top speed went from 55 to 64 mph! Also, my 2001 seems not to have a governor, will turn to 8,500 if you let it.
amalota
Feb 5, 2016 01:45 PM
jppaving
10
Jan 22, 2016 10:10 AM
