Clutch weight housing
Old Jul 7, 2017 | 05:28 PM
Angie Stanford's Avatar
Default Clutch weight housing
Is it safe to run my ATV without the plastic housings? I just changed the belt and noticed that 8 of the housings need replaced.
Old Jul 8, 2017 | 09:22 AM
Zrock's Avatar
Super Quad Patrol
im assuming your talking about the nylon that surrounds your clutch weights. If you take those out you will have no clutch weights and if you take them off the weights the steel will wear into the clutch causing damage
