choke problem??
Old Sep 9, 2017 | 05:18 PM
mikecullup's Avatar
Default choke problem??
I have a 2001 Artic Cat 400. I just replaced the carb and still have the same problem. It will start cold or hot but I have to keep the choke on. If I take choke off it coughs and backfires, runs poor. This Artic Cat has always gone through spark plugs really fast.
Old Sep 10, 2017 | 08:08 AM
hydrex's Avatar
Check the rubber boot between the air box and the carb for cracks, replace if you find a crack. That will make it run lean plus suck in dirt. Normally, I would say check for a speck of dirt in the pilot jet. Is the PMS screw turned out 1-2 turns? Float height set to 17 mm?
Old Sep 11, 2017 | 03:47 PM
mikecullup's Avatar
Thank you, I will check on them.
summit
Sep 8, 2016 07:30 AM
toysforlife
1) Engine problems..
Aug 31, 2016 10:18 AM
HomelessManatee
Aug 5, 2016 10:13 AM
