Arctic cat won't run
Old Jun 27, 2018 | 01:23 PM
Carmen368's Avatar
Default Arctic cat won't run
My 2003 arctic cat 300cc 4x4 will idle but dies out when given gas
Old Jun 27, 2018 | 07:48 PM
hydrex's Avatar
Welcome to the Connection. My uneducated guess would be that you should take the carburetor apart, clean all jets and check float height. You may need compressed air to blow out the jets, they can be very tiny. Might find a youtube video to help. GL
Old Sep 3, 2018 | 06:55 AM
Rubymass090's Avatar
Make sure you're using the airbox too, or it won't have enough of a vacuum for the carb diaphragm. Had this problem myself too
Old Sep 7, 2018 | 04:34 PM
PinkTunaLAO's Avatar
sounds educated enough .. defiantly take carb off and just take it apart .. one piece after another and line parts up in order as you take them off to help remember putting back together .. get a container and some cleaner .. soak the heck outta it and let it dry .. get down to fine cleaning and make sure can see good lighting threw all ports and jets.. throw it back together and might end up not having a problem
kyblev
Jan 15, 2020 11:37 AM
Apr 18, 2017 07:19 PM
santee
Feb 9, 2017 09:38 PM
Feb 3, 2017 03:03 PM
