coolant in oil
Old Jan 27, 2019 | 08:12 AM
9betterboy's Avatar
Default coolant in oil
I have a 1998 454 4x4 Artic Cat ATV. I went out to use it and noticed 12" puddle of anti freeze and when I went to clean it up I noticed it was really thick for coolant. It started ok but spit and sputtered and back fired the whole time until I shut it down. My first thought was it's the head gasket. I didn't see any signs of a head leak. I'm not even sure how the puddle of coolant / oil mix got on the floor. Any Ideas ? appreciate any thoughts.
Old Jan 27, 2019 | 09:52 AM
Kymco 450i's Avatar
Cracked block?
Old Jan 27, 2019 | 10:18 AM
Zrock's Avatar
Super Quad Patrol
Water pump failure
Old Jan 27, 2019 | 11:17 AM
9betterboy's Avatar
I hope not,. really expensive
Old Jan 27, 2019 | 11:22 AM
9betterboy's Avatar
Zrock
Not much experiance with ATV engine's, A failed water pump would allow coolant in the crank case? any way to check the water pump? thanks for reply
Old Jan 27, 2019 | 12:14 PM
Zrock's Avatar
Super Quad Patrol
If it's similar to my pump their is a seal that fits between pump and engine. If that deal fails fluid could go both ways.. rebuild kit is cheaper option
Old Jan 27, 2019 | 01:05 PM
9betterboy's Avatar
Thank You for your help, i'm going to try that its only $17.00 for a rebuild kit. Looks like a good place to start
Old Jan 27, 2019 | 02:23 PM
Zrock's Avatar
Super Quad Patrol
If we had pics of where the oil is we may be able to help better... this is just a guess
Old Mar 10, 2019 | 09:40 PM
9betterboy's Avatar
Just wanted to get back with you and Thank You for your help, It was the water pump oil seal. I would never found that, I had no idea there was a seal between the oil and water there.
Appreciate your help
Old Mar 11, 2019 | 09:33 AM
Zrock's Avatar
Super Quad Patrol
glad you got it fixed
overthehillsgangATVer
Aug 26, 2008 12:22 AM
KenDS
Dec 18, 2000 12:06 PM
425Xpedition
Aug 7, 2000 09:40 PM
