Arctic Cat 300 4x4 Build
Old Mar 4, 2019 | 06:43 AM
  #51
Tanker_01's Avatar
So it starts up and runs awesome now after some tinkering with it. I pulled the plug again to check it and it was pretty black. I turned the fuel screw all the way in to 1/2 turn out. now it seems to run much better, still cant achieve an idle though...
Old Mar 4, 2019 | 01:24 PM
  #52
sr.ruedas's Avatar
Those are classic signs of pilot jet too big. With your pilot screw placement, clockwise is leaner, but it can compensate only so much for a too-big pilot jet. Try a smaller one.
Old Mar 7, 2019 | 02:10 PM
  #53
GWgame's Avatar
Banned
Check the choke is it possible it is activated? I had an aftermarket that I forgot to switch the pilot one on. It would start and idle but would not tach out. Whenever the choke was active it would cause it to rev up but it would not idle.
Old May 5, 2021 | 01:33 PM
  #54
Paul Weaver's Avatar
Default Artic Cat 550 RX
Gotcha. I will do that. Thanks for all the help man.
I’m looking for a motor for a 2015 Artic Cat 550 RX. I think there’s different models that’ll fit it. Do you have any suggestions where to find one? And also some rims and tires?
homedotcom
Jan 4, 2023 04:47 PM
Outdoorsman101
Sep 13, 2010 01:21 PM
wlc
Mar 27, 2010 10:39 AM
BBALICK1
Nov 26, 2007 12:30 PM
BenA.
Aug 16, 1999 11:52 PM
