Clicking with lockers
Old Jun 9, 2019 | 08:11 PM
GWgame's Avatar
Banned
Default Clicking with lockers
Ok so, I have a 2002 AC 400 4x4. I removed the front differential and swapped it with a 2005 650 front diff. I was able to keep the mechanical actuator off the old diff instead of the $120 electric actuator. When I swapped the diff I changed the right inner cv joint (that goes in diff) for the locker ring. When I installed the locker cable, which I am not completely sure how to adjust, and locked the diff it felt like it would lock. When I try to turn with the lockers engaged, then and now, a popping noise occurs. I thought this could have been from the left axle inner cv, so I changed it with a 650 one. No matter how tight I set the cable it will still click and pop. Is this supposed to happen or do I have an issue elsewhere?
Old Jun 22, 2019 | 10:21 PM
GWgame's Avatar
Banned
So I gotta another update. I think it was a bad axle(s) because the left side decided to break tonight.
Old Jul 9, 2019 | 11:31 PM
GWgame's Avatar
Banned
SOLVED! I had a buddy come over when I was putting everything back together. I told him the symptoms and he inquired about the locker cable. When I would turn left the cable was ok. When I turned right, due to how it was routed, it would pull the cable and try to lock the diff. After some rerouting that no longer occurs.
Shane West
Nov 24, 2001 10:40 PM
Rebel-Twolf
Mar 8, 2000 06:17 AM
mpbspb
Jan 10, 2000 07:31 PM
mattsibley
Aug 22, 1999 09:28 PM
