2017 Alterra 700 Fuel System
Old May 30, 2020 | 05:50 PM
H David Sloan's Avatar
Cool 2017 Alterra 700 Fuel System
I know virtually nothing about ATV repair, but I believe that I need to drain my fuel system, and replace the fuel filter on my 2017 Alterra 700 I think I got water in my fuel at some point and the engine seems to be starving for fuel. I am looking for practical help on what needs to be removed to expose the fuel tank/ fuel lines/ and fuel filter so that I can clean and replace as necessary. Thank you for your help.
Old May 31, 2020 | 07:49 PM
Kymco 450i's Avatar
Get your hands on a factory service manual then you should be able to solve most issues you might have. As far as draining the fuel just find where the fuel line goes into the carb, then trace back to the tank. Very easy to get water in fuel nowadays...
Old May 31, 2020 | 07:51 PM
Kymco 450i's Avatar
Woops....see the 2017 year so you probably have an injection system, all the more reason to get a factory service manual. EFI systems can be tricky!
Old Jun 1, 2020 | 11:10 AM
Zrock's Avatar
Super Quad Patrol
Easiest and only way really to get to everything is take 20 min and remove the plastics.. seems like a lot of work but its not and makes like way easier
gohip2000
Jan 22, 2007 10:27 AM
LoneWolfInArizona
Nov 13, 2006 05:07 PM
ZoomZoom
Jan 15, 2001 03:59 AM
