Weird issue bleeding brakes??
Old Sep 10, 2022 | 03:34 PM
Bblawless's Avatar
Default Weird issue bleeding brakes??
Hey guys, new to the forum here.
I’ve got a 2014 arctic cat 550trv.
I recently paid a mechanic friend of mine to re-do the brake system
-brand new rear master
-brand new front master
-pads
i picked it up from him yesterday l, and he had basically given up on bleeding the brakes…which was surprising because it takes a lot to get this guy to give up.
There is no pressure in either the front lever, or foot pedal UNLESS I depress the foot pedal first, in which case I have full brake pressure at the front lever and the quad stops beautifully…
so basically the brakes only work if I hold down the foot lever first, keep it held, and then hit the front lever….
can someone help me make sense of this? Did we miss something crucial in the bleeding process?
thanks a lot
Benny
Old Sep 11, 2022 | 02:09 PM
fixitup's Avatar
I had the same issue with mine. I had to suck the fluid through as just pumping wasn't enough to get the air to move. I think I used a big syringe and a hose to the bleeder valve.
Don
Old Sep 11, 2022 | 05:43 PM
Bblawless's Avatar
Don
thanks for the reply, which bleeder valve did you connect the syringe to?
thnx
Old Sep 12, 2022 | 08:15 AM
fixitup's Avatar
thnx
On the calipers.
Matthew Schwartz
Jan 30, 2016 06:19 PM
mtnhiker19
Jun 29, 2008 07:47 PM
200es
Jun 27, 2008 04:10 PM
Liteshow
Sep 10, 2007 10:38 PM
oldcrow
Nov 22, 2004 10:24 PM
