Mud tires
Old Jul 16, 2001 | 10:21 PM
BlackwhiteRaptor660R's Avatar
What is the best mud tires that do not take away the preformace too much??? And what is the best tire for tug-of-war with quads on loose ground?(4 wheele drive)
Old Jul 16, 2001 | 11:43 PM
BONER's Avatar
I would go with either Mud Bugs or 589s. They are both a good mud tire without effecting the overall performance too much. The Mud Bugs might be better for out of mud performance because of there lighter weight. You might also want to consider GoodYear Mud Runners. They are fairly good in mud with a tread that isn't as likely to be overly grippy when not in mud. They are a good bit more expensive tho.
As for tug-of-war comps. IT depends on the terain. ON hard pack I would run the Stock tires with about 4-5 psi in them. IN mud, I would run 25/26x12x12 Outlaws.
Old Jul 21, 2001 | 11:17 PM
Dana67's Avatar
the 589's are good tires, i just put a set on my machine and what a difference it makes. i like to make trails as i go and these tires are perfect for mowing over stuff and the go incredibly well in the mud. the 589's make blackwaters look like stock tires. later - dana
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
