New tires for 375
Old Feb 17, 2002 | 03:56 PM
needaQuest's Avatar
Since we are talking about Dirt Devils, i have a 2001 AC 500 and was wondering if i would notice ANY power loss with 27x10-12 DD's, top end or low end. I really like my cat being "pepi". I want to keep being able to turn sharp corners in 3rd gear and "rapid-shift" to 5th.
If they do rob a little power i can always go with 26 inchers. I plan on installing a lift so i should have enough ground clearance with either tire. By the way i have 27 and 28" DD's on my Quest and they are an auwsome tire! Thanks for any help![img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 17, 2002 | 04:38 PM
02AC375's Avatar
The 27 inchers I have on my 375 I barely notice any low end power loss. So on your 500 you would be less apt to notice any change. You won't need a lift for the tires because there is more than enough room for them. As far as being able to do any of those fancy corners, the DD's grab a whole lot more than the stockers so it will take a little more effort on your part (weight distrabution/leaning) to get it to do it. hope that helps some.
Old Feb 18, 2002 | 01:11 AM
BONER's Avatar
The 2001 models have less clearance than the 2002 models, so I would recomend a lift kit for your 2001 model. As for sizes, you sound like you might want to stick with the 26 inchers since you are obviously a very sporty type rider.
Old Feb 18, 2002 | 12:11 PM
needaQuest's Avatar
Boner, the 26 inchers were originally what i was going with, but i read somewhere on here that the 26" Dirt Devils only measure around 24" with 5lbs of air! Does this sound right to you? I don't want to go any smaller than my stockers!
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
