AC won't run
Old Mar 31, 2002 | 09:41 PM
chunkyboy's Avatar
Hey guys , let him buy a honda , and a new holland , because thats what he wants , why he posted here I cant' understand , If you don't like it , load it in a pickup get out your check book , your are a happy camper, end of dissusion , btw ford no longer builts tractor they where bought out buy fiat in 1991 , thats why they call it a new holland now , I bought a 1996 5030 ford - new holland tractor , they replaced it with a new in 1997 , it had 421 hours , they had put 223 hours on it trying to get a miss out of the engine ,never did , it allso blew the left brake seal 7 times , the new one did it 3 times , all though it never missed , I had 50 acres of hay on the ground when it done it last , the dealer pitched me the seal and said fix it , 21 thousands dollars , this is what i get , I fixed it all right , that was my 5 ford new holland tractor no more , so go get you a honda be happy
VA CHUNKY BOY
Old Apr 2, 2002 | 08:28 PM
Gowili's Avatar
Well said, my chubby, ATV riding, magazine reading, literate friend...
Chuck
Old Apr 15, 2002 | 12:12 PM
MtnClimber's Avatar
Back to the subject of your 300 Arctic Cat... I have one that was having the same problems and I thought it was the carburetor because an incompetent cat master left the breather pipe half way off the carburetor, which sucked in some muddy water while on a trail causing it not to start. After cleaning the carburetor three times, it still had the same problem. Come to find out the real problem was a intake valve that came out of adjustment and was so tight, it wouldn't close. The compression was 60 lbs. when it was supposed to be 120 lbs. A quick check to see if your valves are seating is to take a dollar bill and put it up to your exhaust pipe and if it pulls it up to the pipe, check your valves. Hope this helps your problem.
Old Apr 15, 2002 | 06:35 PM
chunkyboy's Avatar
hey dude , I had a 250 ac the intake valve was to close on it to , was a hard starter , after a little adjment it was fine to , good point mite be part of his problem after all , chunky
Old Apr 15, 2002 | 07:19 PM
  #15
delta's Avatar
OK hayseed - go buy a honda....And post your complaints in the honda forum. We dont need your one-way mentality here.
Old Apr 16, 2002 | 10:29 AM
  #16
sxr6's Avatar
The only 4wheelers of any kind that needed an engine rebuild & won't last were ridin by 12 year old kids that think 9000rpm is normal because when it breaks DADDY will buy them another one, maybe a HONDA next time !!!! Good luck kid.
