Fowled spark plug?
Old Jul 3, 2002 | 01:19 PM
  #21
mudcat47537's Avatar
I removed the screen indide the airbox on our 250, this helps throttle response quite a bit. The best way to do this is to remove the airbox, less chance of getting trash in the carb. After this I had to go 2 sizes richer on the main jet.
Old Jul 3, 2002 | 05:08 PM
  #22
2fat4moto's Avatar
Steve154, Hightower is correct.
Old Jul 11, 2002 | 10:30 PM
  #23
steve154's Avatar
Update: I have removed the screen in the airbox, put the new carb boot on and went to a stock air filter. I moved the clip to the 3rd position on the jet needle per the Dynojet instructions, but I decided to leave the 126 jet in, instead of going to the 130. I set the mixture screw to 2 3/4 turns out. It is still rich. After 5 minutes of running a new plug I took it out and it was jet black with carbon. I then turned the mixture screw out a half turn and it did the same thing. Which way do I turn the screw to lean the mixture? Any more suggestions?
I am also wondering if I should just leave everything alone? The bike starts up everytime with absolutely no problems and seems to be running just fine. Is there any long term problems that I need to worry about here?
Old Jul 12, 2002 | 07:56 PM
  #24
2fat4moto's Avatar
You need to go down on the pilot. The air screw, or idle mixture screw as you call it, should be where Dynojet says!
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
