over heating poblem ? or faulty light panel ?
Old Sep 2, 2002 | 09:01 PM
pie1's Avatar
hello every one
i went on a ride this week end(was pretty good).all day saturday and just a little on sunday about 150 miles.very dusty-this was in tug hill n.y.
my problem(2002 400 4x4) the temp light came on a couple times then went off,then on again but when hitting bumps flashed on and off. the
next day after sitting all night checked radiator level added 1 beer can of water.we went on a ride(aprox. 20miles) and the light came on again-we stopped to check it out and it was overflowing out the drain tube. let it cool-and continued ride-light came on ashort while later then went off and was fine after that.
any help would be great-i'm stopping at the dealers on tues.
sorry this is so long-but i'm not happy only 384 miles on this machine
thanks pie1
Old Sep 3, 2002 | 03:20 PM
wildweav's Avatar
I had the same problem this weekend on 2001 500 manual. It is overheating if there is water coming out of the overflow tube. My fan quit working and I had to leave it at a friends house. I switched fuses and the fan worked once, but I could not get it to work again. Anybody else out there with a bad fan? Any Suggestions?
Old Sep 3, 2002 | 06:32 PM
pie1's Avatar
my fan works ok-not a problem.
my dealers mechanic told me to research a little-to see if i can get the light to come on when cold.before i bring it to them.
pie1
Old Sep 3, 2002 | 11:54 PM
JohnO's Avatar
My 500i started flickering the temp light when it was in 1st gear low, but only 1st low, not neutral or 2nd low or 1st high or any other gear. Went away after a couple of rides, never came back.
Old Sep 5, 2002 | 01:24 PM
wildweav's Avatar
My brother looked at the cat and found that the "heat switch" had went bad and ordered a new one. I thought that the cat did not have such a switch, I guess I was wrong, at least I don't need to pay for a new fan.
thanks wildweav
Old Sep 9, 2002 | 07:05 PM
pie1's Avatar
my dealer has it right now-wrote it up as warranty-not bad for almost a year old(only 390MILES THOUGH)
ALSO MY FRONT DIFFERENTIAL IS LEAKING THEY ARE TAKING CARE OF THAT TOO.
PIE1
Old Sep 9, 2002 | 08:11 PM
CatWoman's Avatar
Hi Pie,
We had an overheating problem riding in WVa, it was really dry and dusty. We had the quad in water and some mud and then through all the dust. We had to wash out the radiator really well. It helped but later we found out that because it had overheated it cracked the water pump gasket, we bought a new gasket, replaced it and all has been well since. The water from the radiator was dripping out down by the foot boards. The gasket is located down there so if you notice a very slow leak down by the footboards that could be your problem.
Cat
Old Sep 9, 2002 | 10:20 PM
pie1's Avatar
THANKS CATWOMAN
I WILL KEEP THAT IN MIND.BUT HOPEFULLY MY DEALER WILL GET IT FIXED AND UNDER WARRANTY ? BUT SOUNDS LIKE THE DIFFERENTIAL SEALS IS KINDA COMMON.
WHERE DID YOU RIDE IN WEST VIRGINA - HATFIELD AND MCOY ? WE ARE TALKING ABOUT PLANNING A TRIP THERE NEXT YEAR.
THANKS PIE1
Old Sep 9, 2002 | 11:42 PM
CatWoman's Avatar
Yep, we went to Hatfield McCoy, it was great. Went to an event called Dirt Week in June and we are going again this Oct 18, 19, 20 for Trailfest.
Old Sep 14, 2002 | 10:51 AM
pie1's Avatar
well my dealer can't find anything wrong to cause overheating.
he replaced temp. switch on the head-just because.they also replaced the seal all under warranty.this dealer seems to take care of his customers. not bad when i bought the machine in november 2001.
pie1
mywifesquad
8
Sep 21, 2015 08:20 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Steeldon
Sep 9, 2015 09:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
