Problem Starting
I have a 2000 300 4X4 AC. I am having major issues getting it started. Everytime I push the button to start all I get is a single click, never tries to turn over. Lights work and new battery. Any ideas!!!!!
Same problem on 2001 500 auto. check relay in right rear wheel well. (it has a clear plastic cover that slides up when you push a clip). lift the cover and carefull jump the two large leads with a pair of needle nose pliers (rubber handled). With the key on I betcha it'll lite. That'll give you a start
