Tires
Old Jan 16, 2003 | 10:58 AM
Turfguy's Avatar
Default Tires
I have a 500i and would like to know how big of a tire i could go without having to do any mods to the suspention. I am trying to get an idea of what my possibilities are. I also plow and have about 3 inches of clearance when turned all the way. So that would be the other concern. Thanks for the info ya-all.
Old Jan 17, 2003 | 12:40 PM
mudcat47537's Avatar
Default Tires
I'm sure that the 27x10 will fit in front and 27x12 in rear.
Old Jan 19, 2003 | 06:31 PM
Andy Bassham's Avatar
Default Tires
I seriously think that you could even put 28's on a 500i. They have a ton of room underneath. 27's fit easy on my old 99 ACT suspension 500, and I might even have been able to go 28 under it without any mods.
Old Jan 20, 2003 | 03:14 AM
Fango's Avatar
Default Tires
Yes, Andy, I think you're right. 27 and 28's will probably fit. BUT...without a lift or spring spacers...You may have tire rubbing issues. The 500i may be high enough, but I know on my ACT, without a lift, I would rub a little when riding hard.
Personally, I think 27" tires are plenty-0-Tire!! If you want more clearance then lift it!!
Old Jan 21, 2003 | 12:12 AM
  #15
Default Tires
Yeah, I won't go any higher than 27". I think that the diameter has just as much to do with eating away power as the weight issue myself. 27's are pretty damn big to begin with.
Old Jan 21, 2003 | 10:26 AM
  #16
Turfguy's Avatar
Default Tires
Alright guys,
Without starting a war on the best tire, what would be the best 27" tire for muddy ditches and a ton of snowplowing, as long as it snows. Also I am new at this does 27" mean the farthes point of the tread or is it the base of the tire. The reason I ask is I have 3" of clearance with my plow now, If I increase frow a 25" to a 27" does that mean I only gain two inches or is actually more with the type of tread design. This seams like a stupid question, but thats alright its not the first time that has heppened
Old Jan 21, 2003 | 11:30 AM
  #17
65fl's Avatar
Default Tires
I can't help with the first part of the question, but the second part I can. The 27" is the diameter of the tire or as most people call it "how tall". So if you currently have a 25" tire and 3" clearance between the plow and tire, then upgrade to a 27" tall tire, you will have about 2" clearance between the plow and tire. Another way of saying this is that for every inch taller your tire is you gain 1/2" in radius and thus 1/2" in clearance between the bottom of the ATV to the ground, or in the case of the clearance between the tire and the plow you would lose 1/2" clearance.
You also alluded to the fact that differences in tread designs, sidewall designs, tire brands and even tire pressure can all effect the actual change in clearance. I don't think I would want to go taller than 27" for your situation. Good luck in your choice.
65fl
Old Jan 22, 2003 | 01:38 PM
  #18
Turfguy's Avatar
Default Tires
thanks 65fl,
That makes perfect sense, it all is so clear now. Thanks for the reply.
Old Jan 23, 2003 | 10:33 PM
  #19
RotaryRocket's Avatar
Default Tires
Originally posted by: racnooc
Rotary, i would suggest Dirt Devils, ITP all terrain radials, or Bearclaws. as for the size i would go up one size. so 25X9X12 in the front and 26X12X12 in the back. my 26X12X12 outlaws do not even come close to rubbing on my 300 so i am sure with the lift you will have no problems.
Racnooc, are the Dirt Devils an ITP tire? I can not find them on their site.
If not can you provide me with a web site.
Thanks in advance.
Old Jan 24, 2003 | 12:41 AM
  #20
racnooc's Avatar
Default Tires
Rotary, GBC makes the Dirt Devils. You can see them at highlifter.com or rockymountainatv.com
