MY BRAKE LIGHT IS OUT...
Old Feb 22, 2003 | 01:23 AM
ecorman1's Avatar
Default MY BRAKE LIGHT IS OUT...
I read some one else here last year with the same problem. Now my brake light is out in a similar situation. I changed the bulb and the running light works again. The foot brake turns on the light but the hand brake-- NO! Tomorrow I'll test for the wiring circuit. I suspect the hydraulic brake switch is going to be the culprit. I'll let you guys know...
Chuck
Old Feb 24, 2003 | 03:05 PM
nighthawk's Avatar
you might remove your gas tank and check to see if the connector came loose , mine did this also . when i ran the switch wires for my winch some how i unhooked the conn.
good luck
Old Feb 27, 2003 | 10:54 PM
ecorman1's Avatar
Nighthawk, did you have to take all the front end off to find the problem?
Thanks,
Chuck
Old Feb 28, 2003 | 10:40 AM
nighthawk's Avatar
Chucky ..no i didnt have to take the front plastic off..(TG)! just took off seat i think side panels, and then the tank. its kinda tight back in there so grab the brakelight switch wire on the handle bars and follow it down and you should be able to see if its unhooked or not ..
nighthawk
Old Mar 2, 2003 | 07:14 PM
ecorman1's Avatar
OK! Didn't do anything yet. I will try tomorrow after work and come back here to let you know how it turns out..
Thanks again, Nighthawk.
Chuck
Cummins Driver
Sep 11, 2019 01:22 PM
sweaver
11
Aug 18, 2015 03:47 PM
DeFox500
Jul 26, 2015 06:32 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
