454 dies after warm up
Old Mar 23, 2003 | 02:39 PM
Montanacat's Avatar
Default 454 dies after warm up
Help! My '98 454 ATV dies after it gets warmed up (about 6-8 minutes after starting), and won't start again until it cools down. I've cleaned the carb, adjusted the valves, and put in a new spark plug. But no change. It runs perfectly up to the point where it warms up. Anyone know whats going on?
Old Mar 23, 2003 | 04:22 PM
Win3855's Avatar
Is there any spark? If not it sounds like a coil. If there is, then it must be fuel,check your gas cap vent.
Old Mar 23, 2003 | 08:35 PM
Cat500i's Avatar
When it dies pull the plug and see if you have any spark.
Old Mar 25, 2003 | 12:04 AM
CatRider's Avatar
After checking the spark and fuel vent line, check your fuel shut off valve. If you haven't used the valve for a while or don't use the reserve, it can build up dirt.
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
IMLN
Sep 28, 2015 03:32 PM
2many2ride
Sep 27, 2015 04:35 AM
