Detroit locker for Cat's!
Old Apr 4, 2003 | 10:17 AM
Olddirtybastard's Avatar
Default Detroit locker for Cat's!
The pin going through the assembly is also welded to the outer case from the factory.
Old Apr 4, 2003 | 11:00 AM
Cesil's Avatar
i wrote highlifter and this is what they said
we tried but due to the way that AC put it together [front diff,ring gear,carrier] it would require so much machine work [to each one] and then the locker, it just is not feasible . We could sell a lot of them if it could be done at a reasonable price. Thanks for asking
Old Apr 4, 2003 | 11:37 AM
voodoo's Avatar
Understandable from a business stand point but sucks for us. I wonder if its any easier to lock an older machine. There is a different diff in the older machines. Id consider it, it steers like a tank now, dont know if it can get any worse. Anyone want to elaborate on this for me. I cant get at the Browns site to show you the diff.
Old Apr 4, 2003 | 12:58 PM
CatKrazy's Avatar
On the older diffs it is as easy as engaging the lever further down which locks the spiders in a constant posistion. Im not sure if you can put the old diff in the new cats. It would be up to the pinion gear and shaft. if that all matches i dont see why not, unless the older diffs couldnt hold up to the new power of the 03s
Old Apr 4, 2003 | 01:36 PM
  #15
voodoo's Avatar
See there is no "lever" Its full time 4x4 on these models. I would love to take it out of 4x4 and have a lock...!!! Heres the front end...
http://www.brownsleisureworld.com/Parts/ATV/1998/1998ATV5004x4(98A4G-1998)/FRONTBEVELGEARASSEMBLY.htm
shimanok2
Jan 29, 2016 07:37 PM
stcspiderman
Sep 13, 2015 05:15 PM
Rancher4x4ESLuvr
May 25, 2001 05:57 PM
jake400exyellow
May 18, 2001 12:44 AM
Tree Farmer
Mar 4, 2001 11:48 PM
