low range
Old Apr 7, 2003 | 02:35 PM
dcat's Avatar
Default low range
I put my cat in low range to pull out my buddy that was in some mud and it would not go back in high range it just made a clicking sound, i had to trun it off befor it would go back in high range. is this ok, does this happen on cats a lot?
Old Apr 7, 2003 | 02:43 PM
Olddirtybastard's Avatar
Default low range
Mine did that a couple of times on the first ride. I sprayed wd-40 under the handle that you pull up and down an worked it back and forth a few times and it stopped doing it.
Old Apr 7, 2003 | 08:05 PM
Cat500i's Avatar
Default low range
Mine still does this almost everytime I switch ranges. I just rock back and forth a little and it kicks in. I think it's pretty normal.
Old Apr 8, 2003 | 04:33 AM
mudblaster's Avatar
Default low range
cat 500i you took the words right out of my mouth i do the same thing rocking it back and forth seems to disengauge the low and lets it slip into hi i dont think its to serious though its kind of like when your dirt bike slips into that secret nutral and it just clicks same thing
Old Apr 8, 2003 | 07:40 AM
sgable's Avatar
Default low range
Try moving the lever all the way to neutral then put it back into high. This works good for me.
Old Apr 8, 2003 | 11:58 AM
dcat's Avatar
Default low range
[img]i/expressions/face-icon-small-happy.gif[/img] thanks for the help
ReconBayou
Oct 31, 2022 05:37 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
shimanok2
Jan 29, 2016 07:37 PM
Hack714
Sep 26, 2015 08:11 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
