Opinion on my plug color
Old May 7, 2003 | 07:00 PM
CatKrazy's Avatar
Default Opinion on my plug color
CLICK HERE
Let me know what you think
Old May 7, 2003 | 07:16 PM
voodoo's Avatar
Im impressed, you can work the cam and post a link :] Seriously tho, looks like a nice tan color to me, im far from a plug expert. Mine is a lot darker than that. Looks like a good job to me.
You can check this link as well... NGK Plug Colors
Old May 7, 2003 | 07:35 PM
CatKrazy's Avatar
Yea I amaze myself sometimes
Not too bad for a southern country BOY!!hehe
Anyways I went ahead and put her up a notch in the main. i went bigger, Becasue here in the south it gets extremly hot and you run leaner when the bike gets hot and the temp gets hot, so I rinchend her up a little
It takes about 10 mins to completly take down and put together everything ahving to do with the carb!!
Old May 8, 2003 | 09:02 AM
bartojc2000's Avatar
It looked a bit on the grayish side to me. Hard to tell. You're on the edge by the looks of the plug.....again tough to see from the pic.
I think you done good by going a notch richer. Watch the plugs.
One note though.....colder outside temps mean leaner burn....hotter outside temps mean richer burn. I've seen enough sleds burn down at -10F when they were jetted to 30. As the temps drop you want to richen not lean your machine.
-jeff b.
Old May 8, 2003 | 10:54 AM
CatKrazy's Avatar
Yes but where I am from the humidity is so HI and it rises with heat
Im in the delta. Arkansas,TN, mississippi,corner
Old May 8, 2003 | 02:25 PM
The leaner you run, yes the hotter the engine will be. But, the hotter the ambiant temp is the richer your mixture will be. Fuel Air mixture is what I mean. That is why guys who ride in the winter will sometimes need to run fatter jetting in the winter. If they ran their setting at below freezing they'd burn down.
Not trying to argue. I'm sure you know what you're doing. Your post was confusing the way it was written. I wanted to clarify for those that don't know. If you're jetting for conditions, the hotter the outside air temp the richer a given jet setting will run. If you're running on the edge at 90 degrees, you wouldn't want to run that setting at 40 degrees.
As always ymmv......watch the plug color, and/or piston wash.
-jeff b.
Old May 8, 2003 | 10:40 PM
CatKrazy's Avatar
I have 150 mian in now and needle set at 3. Dyno specs called for 3 on the needle and 148 main. SO I htink I will be OK. i will watch the plug
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Schneider
Jul 24, 2015 05:05 PM
Captjay
Jul 23, 2015 12:33 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
