2011 polaris sportsman 500 ho no power to the key
Old Jun 5, 2017 | 07:58 AM
ensort's Avatar
Default 2011 polaris sportsman 500 ho no power to the key
i turn the key on and there is no power but if you run from a hot point to another everything works?
Old Jun 5, 2017 | 08:35 AM
Welcome to the forums.Eliminate the basics such as the battery itself. Make sure it passes a load test plus check all connections and grounds.Unplug the speedo harness,wait a couple minutes and plug it back in. Plus another common problem was the connectors on the left control switch not allowing power to the dash. Clean the pins and connectors with electrical spray and use some electrical grease and see if power is restored.
whitemike
Jun 8, 2017 07:43 AM
Sugarkryptonite
Jun 7, 2017 10:03 AM
Matt Olesnevich
53
Jun 7, 2017 09:14 AM
indified
May 22, 2017 05:50 PM
aborisenko1
May 9, 2017 03:46 PM
