custom 250SX question?
Old 07-22-2003, 11:40 PM
ThreeWRacer's Avatar
Default custom 250SX question?
the 250R forks are longer and have more travel than 350X forks. You can also lower the forks in the triple trees. to get a lower ride hieight
Old 07-23-2003, 01:18 AM
heehaw's Avatar
i see all of that travel but aint that butting a bind on the drive shaft i have a 82 250r rear shock i am going to try if i can find some time
Old 07-23-2003, 05:11 PM
to test how much travel i get on of the shaft drive i put blocksunder the skidpan and took the shock off. I started it and put it in 1st gear and left it on idle. With the wheels off the ground the automatic clutch in gaged. I swung the axle till it binded and marked it. Then i made the shock mounts to be within the binding limit. I took the springoff the shock to make sure it didnt bind. Without the shock on it and the batery case removed it willget about 10 inche of travel without binding.
Old 07-24-2003, 10:50 PM
hehaaw. The shock for the 250r will make it ride harder because its stiffer than an sx spring.
  #15
Old 07-25-2003, 06:24 PM
I wonder if they ever made a bigger engine that bolts right into the ATC250SX frame. And lines up to the shaft.
  #16
Old 07-26-2003, 12:37 AM
250sx's Avatar
valerius tell me more about your swap...did you just drop in the 350x triples & go? were there problems with the steering stops?
  #17
Old 07-26-2003, 02:02 AM
Yea same question as 250sx
  #18
Old 07-27-2003, 12:27 PM
the 250sx comes stock with 22inch tall tires. I would like to put 20 or 18in on it. But i would like to keep my gearing and top speed. Do the make different gears for the rear end on the sx?
  #19
Old 08-07-2003, 03:01 AM
250sx's Avatar
the big red used a slightly different gear, but only b/c it had 25" tires so it wouldn't help you any. I wouldn't go that short on an SX tire...you'll kill the clearance with the shaft drive plus it just isn't made for that.
  #20
Old 09-23-2003, 11:29 PM
its made for it now. It has 8.5 inches of travel.im not lookin for ground clearence i want to race this beast.
Customer Service #1
05-15-2020 08:46 AM
Alex G.
09-19-2015 06:34 PM
carid
09-14-2015 03:40 PM
Quick Reply: custom 250SX question?
