Rear axle aaaahhhhh!!!
1986 Honda 200x, the problem is i'm missing the or have destroyed the rear axle retaining hardware. The two lock nuts, threaded collar, another collar, and a snap ring. My local shop says he doesn't think they can get the parts!!! Does anyone know a good website where I'd be able to get these parts??
Look on the Bikebandit.com site or this site
http://www.powersportspro.com/
Both of these sites offer direct factory replacement parts that will get you back riding. They are both a little slow to get you the parts, but they will have what you need and a nice diagram to make sure you get the right part.
mark
mark
this is off bike bandits site
1: CHAIN, DRIVE
147640-001 $111.81
2: MASTER LINK
149038-001 $5.96
3: SPROCKET (38T)
(38T) 148277-001 $55.16
4: PLATE, CHAIN GUIDE
146499-001 $11.69
5: AXLE, RR.
145646-001 $295.60
6: FLANGE, BRAKE DISK
Fr_Sr_No_To GK501559 143723-001 $64.85
7: BOLT, RR. AXLE
143802-001 $21.93
8: DISK, R. RR. BRAKE
142373-001 $221.18
9: ROLLER, CHAIN
58438-001 $16.76
10: COLLAR, CHAIN ROLLER
58618-001 $6.65
11: BOLT, SPROCKET
233879-001 $3.29
12: NUT, AXLE
236788-001 $12.69
13: NUT, RR. AXLE LOCK
236827-001 $11.16
14: NUT, FLANGE (8MM)
(8MM) 236819-001 $3.15
15: WASHER, AXLE NUT
239667-001 $17.53
16: CLIP (OUTER) (32MM)
240404-001 $1.82
17: O-RING (35X1.7)
244237-001 $2.04
18: BOLT, FLANGE (8X35)
(8X35) 2415-001 $1.03
Hope this helps. They have damn near any OEM part that your dealer cannot or will not get for you!
1: CHAIN, DRIVE
147640-001 $111.81
2: MASTER LINK
149038-001 $5.96
3: SPROCKET (38T)
146499-001 $11.69
5: AXLE, RR.
145646-001 $295.60
7: BOLT, RR. AXLE
143802-001 $21.93
142373-001 $221.18
9: ROLLER, CHAIN
58438-001 $16.76
58618-001 $6.65
11: BOLT, SPROCKET
233879-001 $3.29
12: NUT, AXLE
236788-001 $12.69
236827-001 $11.16
239667-001 $17.53
240404-001 $1.82
17: O-RING (35X1.7)
244237-001 $2.04
