KF Honda ATC200X Frame & Engine ID Numbers
Old Mar 1, 2004 | 12:22 AM
KNOWSALOT's Avatar
The Facility
Default KF Honda ATC200X Frame & Engine ID Numbers
Two variations of the 200X......'83-'85, and the '86-'87
The earlier models were 5 speed engines. The top end is shared with the other 200 models of the same era with the exception of the camshaft, piston, and a cylinder with larger cooling fins. The frame was made from round tubing.
The '86-'87 series has a different frame, body work, and engine than the earlier models. These were 6 speeds. The frame is made from square tubing.
Frame ID Numbers
1983...JH3TB052*DC263800 and up...Tubular swingarm...Black seat & Fork boots
1984...JH3TB052*EC300001 and up...Box section type swingarm
1985...JH3TB052*FK400001 and up...Seat & Fork boots are blue
1986...JH3TB052*GK500001 and up...All white plastic...ATC logo on blue seat
1987...JH3TB052*HK600001 and up...All white plastic...200X logo on fueltank and shrouds.
Engine ID Numbers
1983....TB05E-6000034 and up
1984....TB05E-6100001 and up
1985....TB05E-6200001 and up
1986....TB05E-6300001 and up
1987....TB05E-8400001 and up
Comparison Info Between 1985 and 1986 Models
SPEC.....................1985...................1986
Displacement............192cc..................... ....199cc
BorexStroke.............65x57.8................... .65x60
Comp.Ratio..............9.6:1..................... ...9.5:1
Carburetor.................24mm................... ....24mm
Transmission...........5 Speed...................6 Speed
Length.....................72.8 in.....................73.2 in
Width.......................41.3 in.....................42.5 in
Height......................40.9 in.....................41.3 in
Wheelbase..............47.6 in......................47.6 in
Seat Height.............27.8 in......................28.7 in
Ground Clearance.....4.9 in........................4.7 in
Fuel Capacity..........2.6 Gal......................2.7 Gal
Front Suspension....7.3 in........................7.6 in
Rear Suspension.....6.7 in........................7.2 in
Dry Weight..............282.2 LBS.................277.8 LBS
mr-tigger84
Jun 29, 2015 05:30 PM
gdmclnh
Jun 13, 2015 05:32 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
lovinhonda
Jan 25, 2000 09:17 PM
