1984 200 bigred trike
Old Aug 20, 1999 | 11:06 PM
bigmanMH's Avatar
I have oil leaking out under my pull start housing would thicker oil help or is there somethin else i should do
Old Aug 21, 1999 | 04:16 PM
Mud600's Avatar
Is there a crack under the pullstart housing or did u just see oil coming off of it. Is there a seal inside the housing? I have a 82 185s and it seems like the pull start is all ways giving us problems.
Old Aug 21, 1999 | 06:12 PM
Tree Farmer's Avatar
Probably shaft seal leaking. I think the shaft extends through the casing into the starter housing. A leaking seal permits oil to enter the starter housing, leaking down the case side and out from the edge of the starter housing where it joins the case cover.
Hie thee to the Clymer service manual from PowerSports Mall on the ATV Connecton home page! (Your Honda parts man might let you see the microfiche picture of this assembly; if he's a really good guy, he'll give you a print of it).
Tree Farmer
timster911
Jul 13, 2015 01:57 PM
bigmanMH
Mar 2, 2000 02:57 PM
bigmanMH
Jan 22, 2000 02:12 PM
bigmanMH
Jan 10, 2000 06:47 PM
