1984 200x Hesitation/Sputtering
Old Jul 26, 2004 | 05:43 PM
200XDiego's Avatar
Default 1984 200x Hesitation/Sputtering
at high rpm's.
Plugs gapped at .020.
Any info or thoughts what might be causing this?
Old Jul 26, 2004 | 06:09 PM
ramblincowboy's Avatar
Hey
I tuned up my friend's 85 200X and it too was sputtering at high RPM's. Took the carb off (it was quite dirty with varnish) cleaned it and ran very good after that. Just my opinion...
Rick
Old Jul 26, 2004 | 06:15 PM
200XDiego's Avatar
I'll try that thanks...
Old Jul 26, 2004 | 07:41 PM
PlatinumDogg's Avatar
yeah, definately look into cleaning the carb, remove the jets, soak the carb in carb cleaner or something similar...then blow out each oriface with compressed air...should clean things up a bit, also blow the jets out too
G/L
sean
Old Aug 7, 2004 | 10:52 AM
ThrashAndCrash's Avatar
200XDiego......did you have any luck? Also my book said 24-28 for your plug.
Old Aug 9, 2004 | 12:31 PM
200XDiego's Avatar
I bought a carb kit... and it turned out one the jets was making it run too rich in fuel, so I switced the jet and it ran perfect. Thanks for all the help to everyone who responded!!!
timster911
Jul 13, 2015 01:57 PM
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
justindeters1
Oct 30, 2000 02:37 AM
GLAKPAK
May 23, 2000 03:35 AM
Ryda
May 15, 2000 08:50 PM
