250sx kick start not catching at all
Old Oct 13, 2004 | 11:23 PM
jusjimbo's Avatar
Default 250sx kick start not catching at all
I have a 1985 honda 250sx,Everything works great on the bike but the manual kick start,It does not catch at all and when i shut the bike off I hear a winding down sound like something is spinning and it comes to a stop after about 3-5 seconds.Electric starter works great.any ideas,I am about to just pull it apart to see whats the deal
Old Oct 14, 2004 | 09:10 AM
broook's Avatar
Sound very much like the "one way clutch", Honda calles it a sprag clutch, located behind the centrifical clutch. If you don`t replace it the spinning and clunk you hear will eventually ruin the teeth on the end of your starter and starter gears. This as a very common problem with the 85-87 big reds. I have replaced lots of them around here. It`s not a big job but you will probibly need a right side case gasket if the cover has never been off before.
Old Oct 19, 2004 | 08:28 AM
broook's Avatar
So what happened. Did you fix it??????????????
Old Feb 19, 2005 | 12:55 PM
ThreeWRacer's Avatar
I had the same problem. While i was in the case fixing it, I decided to try something different and converted it to manual clutch. But the problem in mine was the gear came off of the shaft it rides on, It doesntseem to have a clip that holds it on or anything..
Old Oct 5, 2005 | 02:36 AM
Anthony250sx's Avatar
yeah my 85 250sx kick start goes out of gear blasted thang try to look kool and kick start and hick as hard as you can ad its just like stomping on air but usaly comes bacn and hits your ankle !!! OOOOWWWWEEEEEEIIIII
alix
Jun 28, 2015 03:28 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
4trax300ex
Jul 29, 2000 11:41 AM
