84 250r crank
Old Mar 8, 2005 | 10:23 PM
chili3's Avatar
Default 84 250r crank
My 84 250r needs a new crank, or just the ignition side. I am doing a new top end rebuild, and found the crank worn out, where would be the best place to look?
Old Mar 9, 2005 | 12:06 AM
chipdog4's Avatar
You were doing a top end job and noticed that the shaft was bad, the rod was bad, or the rod bearings were bad?
My crank bearing was bad so I went ahead and got the Hot Rods installed on it.
Old Mar 9, 2005 | 01:12 AM
chili3's Avatar
I just got the trike and it started to smoke and knock. So I tore I down as planned when I got it, the top end wasn,t as bad as I thought it would be. Upon further tear down I noticed that someone rigged the crank nut to stay on (just barley) took the rest of it apart and the crank is just flat out worn out- seal area, bearing surface, thread,s for nut, rod spacers.
Old Mar 9, 2005 | 09:30 AM
chipdog4's Avatar
You're going to have to find a used one on ebay. 81-84 will definitely work.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
