help with 1984 yamaha 200
Old Apr 4, 2005 | 09:55 PM
mkay's Avatar
Default help with 1984 yamaha 200
hi , My 200 is in great shape but ever since uncle tore the engine apart to fix the shifter oil leaks out of the casing on the left side of engine. Is it just a bad seal. And when i try to idle in gear it dies on me, im not sure whats wrong. PLease help
thank you
Old Apr 5, 2005 | 07:26 PM
paulie83's Avatar
most likely a bad gasket or shifter seal does the machine idle in neutral??
Old Apr 5, 2005 | 09:44 PM
mkay's Avatar
hey,ya it itles in neutral but not in gear
thanks
Old Apr 5, 2005 | 09:49 PM
paulie83's Avatar
i would say it is either your clutch improperly adjusted if it is a manual or if not then adjust your idle up a little bit the load of the motor going into gear may be enough to kill it
buddieboy
Dec 9, 2016 05:50 PM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
black_thunder
Sep 22, 2015 07:59 PM
