Air Scoops
There should be mounting inserts built into the tank. You may have to drill your own holes in the scoops. Make sure you mark where the holes should be then drill them away from the tank. I noticed Maier plastics don't come with mount holes in their fenders. They do have molded spots where the holes should be. At least on the front fender they do. So I'm guessing that is all your problem is with the scoops.
i looked up on a site and found this............ Clarke 3 gallon tank - fits ATC 200X (All Years)
Uses stock mounts and petcock. Cap furnished. Cannot use stock shrouds.
#1383
it doesn't have the mounts for the scoops
#1383
Customer Service #1
May 15, 2020 08:46 AM
Aug 28, 2015 09:33 AM
