350x Light Prob.
Old Jun 28, 2005 | 12:57 AM
thebutelr's Avatar
Default 350x Light Prob.
On the X the lights went out a while back but they went out on bright then on dim, then a couple weeks later the tail light went out. But yesterday i got out and checked the bulbs and none of them were burnt out. So i got to lookin around and i found a wire broken off at the base of the AC Regulator. I'm not totally sure but i'm thinkin that my light problems are comin from this because all the other wiring looks solid. Also if that is the problem will a 250x AC Regulator work (i priced a new one for a 350x and its $90!!)? I looked on ebay and they go for pretty cheap and they look identical except for the wires which i could just cut the end off of the 250x one and wire it on the end of my still good 350x wires. Just a thought, well i'm out tell me what ya'll think could be wrong. Thx.
Old Jun 29, 2005 | 01:45 PM
MY86ATC350X's Avatar
if you remove the regulator the lights should still light up but dont revv it might blow up the bulbs. check you wiring that comes from the stator its big red one make shure its tight. if that doent work mabe your light switch is having issues check that out first.
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Alex G.
Sep 16, 2015 12:13 PM
