Cam Chain Help
Old Sep 11, 2005 | 01:01 AM
thebutelr's Avatar
Default Cam Chain Help
I'm in the process of tearing my top end apart for a rebuild but i'm kinda stuck now. I've been following my service manual very closely on the disassembly of the motor but i still can't see how to get the cam chain off of the sprocket. Is there some way of loosening the chain so i can slip it off of the sprocket? If not then how is it supposed to come off? Thx.
Old Sep 11, 2005 | 11:55 AM
ThrashAndCrash's Avatar
take the 2 10mm head bolts out of the cam sprocket, then stide the sprocket off the cam a touch, and work the chain off...........is that what you needed?????????
Old Sep 11, 2005 | 09:46 PM
thebutelr's Avatar
Well not exactly, see the manual i have forgot to specify that you had to take the cam chain tensioner all the way out while i only took the main bolt out. Good lord what a difference it made when it was out! lol. So now i have everything apart and i'm tryin to see if the bore is stock, i'm almost 99% sure it is but there is HF-2 stamped on the side of the piston then HA5 below it. Does this sound stock or does the 2 mean .20 over? I need some help asap cuz i'm wantin to order my stuff so i can get back ridin soon. Thx.
Old Sep 12, 2005 | 12:34 PM
PM Knowsalot.......I bet he will know if those #'s mean anything.
Old Sep 12, 2005 | 07:20 PM
thebutelr's Avatar
Well my grandpa and I finally decided that this was the original piston put in there from the factory 20 years ago so no wonder this thing was feeling a little under powered. Oh and another thing the piston had about a little over an eigth of an inch of carbon buildup on the top and it looked really wavy and a little bit grooved. Right now i've got my wiesco 10:5:1 on the way and my cam from webcycle cams, so do you think this'll give me a pretty good boost in power over what i had?
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
