new here, need help! 250r wont shift to 5th
Old Oct 17, 2005 | 02:14 AM
monster84r's Avatar
Default new here, need help! 250r wont shift to 5th
hi guys, i love the site. any way, my 1984 250r atc wont shift into 5th gear for some reason, i was wondering if anyone could help. i was told by the previous owner that he tweaked the shift pattern so that 1st is a full click from neutral, and 2nd is a full shift from neutral, thus making me have to double shift to get to 2nd. is there any way to check stuff out without splitting cases? i have a manual but no torque wrench. all help appreciated. btw, i dont think the previous owner split the cases, but he took apart the clutch and fooled around with the shift detent.
thanks for any help!
Old Oct 17, 2005 | 09:07 PM
monster84r's Avatar
does this sound like a shift detent problem? how can i determine whats wrong? im inclinded to do anything besides splitting the cases.
all help appreciated!
Old Oct 18, 2005 | 06:56 AM
atc86r's Avatar
Drain the oil and run a magnet thru it.
Old Oct 19, 2005 | 02:08 AM
monster84r's Avatar
run a magnet through it? through the oil or through the inside of the tranny? i assume im trying to find shavings in my oil. il go try that later today, but what does the problem point out? what do you think the culprit is?
all help greatly appreciated!!!
Old Oct 19, 2005 | 02:11 AM
monster84r's Avatar
bump
Old Oct 19, 2005 | 06:23 AM
atc86r's Avatar
Could be a clip holding gear in place broke. Maybe the dogs on the gears are worn . If you find pieces of metal than split the cases. Its easy. I've done it.
Old Dec 5, 2005 | 10:50 PM
lawnboymelvin's Avatar
if you find peices of metal in oil that means that 5th gear is broke or missing peices
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
