Rear end locked up ?
Old Nov 11, 2005 | 05:20 PM
Alans250sx's Avatar
Default Rear end locked up ?
I have posted here in the last week about my rearend. Well today was the day to take it apart and see why it was clanking in the rear. I drove it from my backyard to the front and it locked up now ?? Any new idea's ? If it was the berrings like I have been told would it eventully do this ? Lock up ? Or other problems ? It kinda rolls backwards a little,but not forwards. and that is it being in N ?
Thank guys :-)
Alan "newbie"
Old Nov 11, 2005 | 08:49 PM
JkAss's Avatar
Remove your chain and see if it will move. If it still doesn't move, you will need to tear the rear end apart and see what seized up. If it does move you need to check your front sprocket for movement in neutral.
Old Nov 11, 2005 | 10:39 PM
specialtool's Avatar
How are the boots on the driveshaft housing?
Or if it was run low on gear oil too long, might have locked it up.
Old Nov 12, 2005 | 12:34 AM
Alans250sx's Avatar
Bike is shaft drivin not chain drivin.....Rear end has oil...unles it leaked out I will have to check...If I have oil why would it lock up ?
Al
Old Nov 14, 2005 | 01:16 PM
3wheelerdude's Avatar
You could have broke gears in there even if you have oil. Could also be debries or peices jamming the gears. I doubt it would be something serious.
Old Dec 5, 2005 | 09:49 PM
lawnboymelvin's Avatar
i would have to guess that a gear is popping off the shaft and is catching on another gear maybe check pins that hold gears
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
