tubes in tires???
Old Jan 27, 2006 | 05:09 PM
lawnboymelvin's Avatar
Default tubes in tires???
i was wondering if you could put tubes in atv tires i heard a rumour that the stems will be broke off any ideas???????????
Old Jan 27, 2006 | 05:58 PM
JkAss's Avatar
Yes and Yes. You can put tubes in them, but they tend to spin inside the tire if you don't run alot of pressure in them. I know I don't like my tires with that much pressure.
Old Jan 27, 2006 | 08:02 PM
oldkawi's Avatar
If you do it get metal stems, it helps a bunch.
Old Jan 28, 2006 | 10:08 AM
ok thanks i need tubes because the air leaks around the rim on the front tire an the one rear but the other has a tube in with metal stem and it seems to work alright.
how do you like my pictures of my project let me KNOW!!!!!!!!!
Old Feb 3, 2006 | 10:13 PM
ok my friend has a quad and he had tubes in tires and got around the house once and then WAM 2 tires had both stems sheared right off so i guess its best to go with metal stems
Old Oct 16, 2006 | 06:10 PM
BajaDave's Avatar
Hola! Thought to bring this message up again. 82 Honda 185S has split rims, rubber ring long gone, tried tubes with metal stem, still blew tube. Dont like high air pressure also. Got stuck out in middle nowhere, silicone heck out of rims and crawled back to campo. My thought to try silicone (or something) between split rims to seal? Scrounged old solid rim 4bolt pattern, but need at least one more. Many big brain ideas on this forum, so want to join to ask question. Am I wasting time with split rims? Gracias!
Old Oct 16, 2006 | 07:31 PM
hello. well i bought some tubes for my tires awhile ago with metal stems. it was a bitch tryng to get the bead broke on the tires so i finally took it to a friend. i got the tubes in and put the right amount of pressure in them and they havent blew yet so i dont know. ive never dealed with split rims so im not sure what kind of tube will work? I think you might need the rubber seal to protect the tube. were is the tube popping?, near the stem? or is the tube popping somewhere else
melvin
Old Oct 16, 2006 | 07:37 PM
mattshonda's Avatar
also if you like to ride on two wheels your tires comwe off the rims
Old Oct 16, 2006 | 07:39 PM
i go up on two wheels by leaning over on 1 side and nothing happens?
Old Oct 16, 2006 | 07:40 PM
oh and i think a gear in your transmission might have broke or somthing with your three wheeler
