camshaft seizing
Sorry. About the only thing I can help you with is the oil pump.
I only have 1 parts engine and its the one with the siezed cam, the sprocket cover is missing and the plug wire is not O.E.
Once I get the oil pump out we can make arangements. Were you able to remove the pump without removing the clutch?
If I get it out I can get it sent to London for free can you pick it up there?
Good to see someone as young as yourself taking an interest in small engines etc. it's a cool hobby.
dont worry about the oil pump i just found out there was a hole with a peice of dirt that i cant get out so the oil pump is fine. the oil pump is a little different on a 200m then a 200s the gear shape is a little different so it wont work. but i really need the cam and spark plug wire so i will look around
thanks anyway
thanks anyway
#16
i have found my problem there was a little peice of dirt in one of the holes and i cleaned it all up but now theres a big click when i put it in gear it has alot of free play on the shifter. what is wrong?
exmotocrosser
Sep 13, 2019 06:12 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
