Honda atc 110
Old Jun 3, 2006 | 01:40 PM
supertrike's Avatar
Default Honda atc 110
My atc 110 has just had a new carb, but i thinks something wrong. Before, i started it, and i instantly got lots of white smoke, and a very loud sound. I think the carb i put in had been fiddled with, what are the correct settings for the screws? I'm thinking the noise might be the new exhaust i just put on, but i'm not sure, i stopped thengine pretty much straight away. Would the white smoke indicate water has got in, and its just evaporating? Anyway i cant start it not, but i seem to have a spark. The spark looks an orange/redish colour i think. shouldnt it be blue? Why would it be reluctant to start all the time? and finally, when i start it cold, should the choke be 'open' of 'closed' ? When it did the loud noise and smoke thing, it started stuttering, and it did that thing when i flipped the choke lever. Any help is gratefully recived.
Old Jun 6, 2006 | 01:33 PM
nomoregoodnames's Avatar
have you tried to push start it?
as for as the carb goes turn the idle screw all the way in and with it idling
slowly back the screw out til it has a nice smooth idle i think its about 1&1/2 to 2 turns out
white smock means too much gas not enough air common after you change the carb
it should work itself out
cold start choke should be on or 'closed'
cant help you on the orange spark
remember always have fun
half the joy of owning an old trike is keeping running w/ your own 2 hands IMO
Old Jun 18, 2006 | 05:42 AM
crazyrider1's Avatar
HOW MUCH OIL DO YOU HAVE IN IT
SOUDS LIKE POSSIBLE COLLAPESED OIL RINGS
YEA SPARK SOUND ALITTLE WEAK,I HAVE A BIKE W/ WEAK SPARK AND IT RUNS FINE
DID IT BACK FIRE?????
CHOKE---CLOSED
RUN----OPEN
TRY 1.5 TURNS OUT ON THE AIR SCREW
ADJUST IDLE AFTER YOU GET IT RUNNING
SOUNDS FLOODED
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
