Next project
Old Jul 24, 2006 | 06:37 PM
Joshwfl's Avatar
Default Next project
Just got this today, I traded a 1993 Mazda 929 with a blown motor for it. It runs great! Can anyone tell by the pics what year it is?
http://i28.photobucket.com/albums/c212/Joshwfl/4-1.jpg
http://i28.photobucket.com/albums/c212/Joshwfl/3-2.jpg
http://i28.photobucket.com/albums/c212/Joshwfl/2-1.jpg
Old Jul 24, 2006 | 06:57 PM
JkAss's Avatar
Maybe an 80. It looks like a 185. There should be a sticker on the frame up by the front forks that shows the year.
Old Jul 25, 2006 | 12:14 AM
HondaMechanic's Avatar
none
Old Jul 25, 2006 | 12:42 AM
lawnboymelvin's Avatar
its a 185 because i seen that thing on ebay and he said it ran goodbut is missing headlight and trunklid
Old Jul 25, 2006 | 01:20 AM
JkAss's Avatar
the 185S had the 1.5" suspension on the front forks.
Old Jul 25, 2006 | 04:32 AM
KNOWSALOT's Avatar
The Facility
I see 1980 185 or 1981-1982 200 Chassis and front fork there.
And the tank is from a 1983 ATC 185S.
The seat looks a bit funny to me. The only seat to have such a long front was on the later 200M, but it didn't protrude up the tank THAT far. Maybe an upholstery mod??
I couldn't tell from the pics what the left side handlebar switch looked like.... But if it also has the headlight switch intergrated into it, you have a 1982 ATC 200. If it doesn't then you have a 1980 ATC 185...or a 1981 ATC 200.
1982 was the last year for the rigid fork on anything larger than the 110 at the time, so it will most definately be one of those 3 models......considering the forks haven't been changed. If they have been changed, you could be dealing with several possible models then. HaHa!!
If you need further info, post the frame numbers and engine numbers here so that we can break them down and you will know what you have before ordering replacement parts.
Good luck with your new project
Old Jul 25, 2006 | 06:21 AM
none
Old Jul 25, 2006 | 09:00 AM
Joshwfl's Avatar
It has the integrated light switch, motor number is TB05E-xxxxxxxx, just found through Honda that it's an 82 ATC200. Thanks guys!
This one wasn't on ebay though.
Old Jul 25, 2006 | 10:56 AM
what how could it have not been on ebay i seen one with the exact and i mean exact picture and it was missing the head light and trunk lid. and an 82 200 has electric start and reverse even maybe hi low range. this is a 1980 185 because it has no front suspension and is very small
Old Jul 25, 2006 | 01:58 PM
KNOWSALOT's Avatar
The Facility
The 82 200 BigRed is what you are thinking of. It had the reverse and elevtric start. The regular 200 did not have either.
