200x 3-wheeler
Old Sep 11, 2006 | 10:31 PM
86honda200x's Avatar
Default 200x 3-wheeler
wow if anyone needs swingarms or other racing parps check this out http://podosracing.com/main.html
is that a good price?
Old Sep 11, 2006 | 10:49 PM
HondaAtcRoxz's Avatar
are you talkin about the atc swing arm for 290.... that seems expensive. I would check to see how much someone around you would do it for before doing that. I bet for 150 or less you could get it done... Plus not all atcs are the same size in the swingarm unless they will specially make it for your 86...
Old Sep 11, 2006 | 11:00 PM
o0o ok thank you alot and also i found these tell me if its good plz?
http://www.durablue.com/shop_cart.php
Old Sep 11, 2006 | 11:07 PM
There is nothing in your shopping cart...
Old Sep 11, 2006 | 11:09 PM
  #15
ok sorry about that waisting ur time hows this? Axle Hon-250r '82/200x '82-85 Elim 2+2 (the 200x application requires a '81-82 250r sprocket) $489.70
Old Sep 11, 2006 | 11:31 PM
  #16
That wont work... That is for an 83-85 200x. There are two different modles of 200x's. 83-85 and the 86-87 they are COMPLETELY DIFFERENT!!! There are ALMOST NO parts that will interchange with these sets of years. You will have to find an axle to fit an 86-87 200x. I have an extended axle on mine but I dont know what kind it is it is probably from years ago when durablue use to make extended axles for this 200x modle. They do not make them for this modle anymore.
Old Sep 11, 2006 | 11:41 PM
  #17
o0o ok sorry um do u think shops can make them out of solid poles?
Old Sep 11, 2006 | 11:46 PM
  #18
I do not know. I am sure if you had the money to spend then you could have just about anything made. I would use the hardest steal that you can find. If you do this let me know the results cause I might be interested if you find something out...
Old Sep 11, 2006 | 11:49 PM
  #19
ok i will and i am going to make a forum saying i am looking for the parts to see if somone responds and thank you u were a great help i rated u a 10
Old Sep 11, 2006 | 11:54 PM
  #20
LOL you cant put you need parts in a forum... We have a classified ad on here where you deal with selling and things. If you post it, it will just be erased. Sorry thats just how it works
