185s weak spark need help fast thanks
Old Dec 1, 2007 | 11:21 AM
joshjines's Avatar
Default 185s weak spark need help fast thanks
hey my atc is a 185s it looks like a 200x tho but i think it has weak spark because i can see the spark but not fill it and it wont start the carb is brand new so is the cdi and stator the spark is blue sometimes white and instead of a bunch of spark it only has 1 medium sized blue spark sometimes it will start like if i put it in 5th gear and i push it real fast it will start but not stay running one time i got it to stay running and it ran like **** than i shut it off to change the gap in the plug and now it wont start back up but it will fire than die PLEAS HELP YOUR ANSWERS WILL MATTER TO ME THANKS
Old Dec 1, 2007 | 12:02 PM
hondabuster's Avatar
Check the valve clearance, especially the intake valve. If its too tight, the compression drops like a rock. For the weak spark....have you looked at the stator and pick up coils? On those older motors, the stator would get rusty, and the oxidization on that stator and pick up coil would cause weak spark.
Old Dec 1, 2007 | 12:07 PM
joshjines's Avatar
ill tell you the story what happend about a year ago i went for a 6 hour ride got back shut it off next it runs great and the next and the next finnaly i start it up ride for a lil bit shut it off it lost spark the spark was slownly fadding away got a new wiring harness fired up the 3rd pull next day no spark pull it around with the rider it got spark fired right up the next 2 weeks finnaly just quite sparking i got it to spark now it is a medium sized blue spark sometimes white i dont fill the spark if i push it real fast in 5 gear it will start than die the carb cdi and stator is brand new and i ohm the coil and it checks out good im stumped that stuff that you told me to check but sorry i have no idea what that is thanks for replying
Old Dec 1, 2007 | 06:48 PM
Some call it checking the valve lash, some say valve clearance If you get a clymers or other service manual, itll describe the procedure for checking it.
Heres an article on generic valve checking, it should give you a good idea on what to do.
http://www.motorcyclecruiser.c..._adjustment/index.html
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
RickyMac
Mar 5, 2016 07:27 AM
Hatrackr
Aug 11, 2015 09:03 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
dougn85
Aug 5, 2015 07:20 AM
